Scott foil seatpost clamp
zulu23
Hi Guys,
The seat post adjustment clamp is recessed into the frame and is accessed by removing a 3mm allen key bolt to remove a cap on the top tube. this allen key bolt has been rounded off and I need a replacement. Anyone know where I might be able to find one?
Thanks,
Mark.
Vapin' Joe
Formerly known as Smokin Joe
Take it to your LBS or a DiY shop and get a replacement. It will only be a standard bolt.
If you have trouble removing it tap a Torx bit into the rounded hex socket and you should get enough bite to turn it.
