Katana
Hi guys, just wanted to pick your brains. I need to change the seat post insert on my recently acquired Trek Madone SLR9 which I bought second hand. It’s size 54cm(Medium) so it came standard with 160mm seat piston insert with 25mm offset. Whereas large models come with 205mm insert. I need to raise the seat height therefore 205mm will do the trick. Although 205mm insert is available in both 5mm and 25mm offset but I can get a 5mm for under £80 whereas 205mm is for £200. Since the difference in size is of only 0.7 inches therefore inclined to think that it shouldn’t make a huge difference in riding position? Any thoughts
