Shimano cranks with SRAM Force groupset
JaAnTr
Hi,
At the moment I have a full SRAM Force groupset but am looking to get a used Stages powermeter off eBay. There are way more Shimano 105/Ultegra ones for sale than SRAM ones so was just wondering if a Shimano crank will work ok?
Thanks!
smutchin
Cat 6 Racer
The Red Enclave
What bottom bracket does your bike currently have? You'll probably need to change that for a Shimano one as well - easy enough job and not expensive.
lpretro1
Shimano crankset would work with SRAM shifters - but you'll need to look at the bottom bracket as axle size is different
J
JaAnTr
The bike is a Planet X RT58 SRAM Force but it seems to have disappeared off their website so I can't find anything out about it.
smutchin
Cat 6 Racer
The Red Enclave
I just found a list on the site that says the bike uses a threaded bottom bracket. (If you're interested, the relevant info is here: http://www.planetx.co.uk/news/products/q/date/2015/05/12/bottom-bracket-guide )
This would be a suitable inexpensive replacement, compatible with a Shimano crankset:
http://www.chainreactioncycles.com/shimano-tiagra-4700-bottom-bracket/rp-prod137762
You'll also need one of these to install it (and remove the old one):
http://www.chainreactioncycles.com/x-tools-pro-shimano-bottom-bracket-wrench/rp-prod55935
J
JaAnTr
Ok thanks for the help! So if I replaced my BB with a Shimano one, and then bought a stages powermeter that was Shimano then I'd need to buy a right sided Shimano crank too right?
Loch side.
Right. But I don't think you'll find a right side only but I stand to be corrected.
