Slip
eldridge
Altrincham
Hi all
I've just put my steel Boardman back on the road but I'm getting a bit of chain slip down on the bottom of the cassette is this a worn chain?
I'm pretty sure the gears are adjusted correctly.
Thanks for any input.
Cheers
Eldridge.
Quite possibly, measure it. If so, may well need new cassette too
Levo-Lon
Sure its the chain? The free hub may be sticking so that can feel like chain slip.
If its the chain as above, if it's a sticky hub, quick service will sort that
eldridge
eldridge
Altrincham
If I remember correctly I did have the slip before I took the bike off the road, the cassette is pretty clean tbh and the gears are set correctly as far as I'm aware.
I have ordered a new chain we will see how that goes and report back.
Thanks for the help.
treblig
Member
Sometimes a few sticky links in the chain can cause slip if they are not allowing the chain to engage.
Ajax Bay
East Devon
If you're getting slipping, then this isn't just a worn chain, it's a worn cassette and chain.
If the "cassette is pretty clean" it's because you've cleaned it ans not/scarcely ridden it. Difficult to tell by inspection if a cassette is worn beyond use.
Absolutely no point in measuring the chain or scrabbling for esoteric possibilities: sticky freehub, sticky chain links.
Buy both and install. Just replacing the chain will make the slipping worse - and right across the cassette - because the (now worn) cassette has grown up with the chain and can cope with it, except on the sprockets you use most for putting power down.
eldridge
eldridge
Altrincham
Yeah Ajax Bay still slipping, gonna need a cassette, thanks for the advice.
