nickg
- Colchester, Essex
So with the trainer Ive pictured is that speed sensor it comes with?
Daft question but have you taken out the sensor and pressed the button inside? If not, or you don’t know where it is then this may solve your problem.....there are 2 or 3 screws on a cover near the back on the right that houses the sensor. Take these out and the sensor will come out. Slide up the cover to the misuro b+ sensor and there is a tiny button and LED inside. Press the button and the LED will blink 12 times after which it will communicate with your device. Make sure it all goes back in the same way it came out!Well got my cassette today. Installed on to the trainer and attached the bike.
Do you think I could get it to connect with Zwift??? No I could not. So pack it away as had to go to work and hopefully try again tomorrow.
Trying to use iPhone as a link to windows pc. And using Bluetooth connection.
If anybody has any tips then it would be greatfully received.
Hi. Can I use my smart tv to display Zwift wireless or would I have to connect to a pc and use an hdmi lead to TV??
If you have a iPhone and older appletv then yes you can, with airplay.Hi. Can I use my smart tv to display Zwift wireless or would I have to connect to a pc and use an hdmi lead to TV??
