Somebody will no doubt be along to answer from their experience. Have you contacted the manufacturers? quote]
What, before seeking the collective wisdom of CC members? Pah!
I will give them a try after I've had some replies here...
Just upgrade the forks and have a disc front and V brake rear. The rear brake contributes little to the overall stopping power. You probably could have the frame modified if it's steel, but whether it's worth it, only you can say!
Somebody will no doubt be along to answer from their experience. Have you contacted the manufacturers? I had an AZUB -4 (Fairly similar kind of layout.) with V brakes and felt braking was always a bit marginal from high speed, which I only ever managed downhill, but pulling up from 50+mph/80kph* was 'interesting'. I did think about adding a front disc, but frankly the rear V-brake was probably 'good enough'.
I sold it when I was advised to only ride 3 wheels.
* It had 81 gears ranging from 15" to 150", yes 1 5 0 !
