Drago
- Suburban Poshshire
Im surprised Silva gets such a good Internet signal in his cave.
The US States' "Consumer Product Safety Commission" decided to judge as I said:About post:
In the directory / Shimano Failures / Cranks:
What is named (hence the quotes?) "welded" is instead likely forced-bended (forging) "into" eachother, much like the male/female sides of pushbuttons each consist of, to attach to the fabric.
Shimano changed that to glueing, and Trouble Came, once again, in Shimano Paradise.
According to aboves specs:
- Ultegra models weight "win" towards the previous 105 was 705-685=20 gram, coincidently the same creditcard-calibre weight difference of this topics Spindle Snap that my calculated 29% better torsion resistence delivered by increasing the shafts wall thickness with 50% towards the inside (thus the outer 24 mm staying as required).
- Dura-Ace model increased that "win" to 76 gram.
https://bike.shimano.com/en-NA/info...owtech-road-cranksets-inspection-program.html
Soooo, Shimano Says there implicitly that in July 2019 they changed something in their production, that would have (I guess we'll see about that in the future) solved the problem they Didn't Know at that time (yes lol), and kept on declaring till september 2023 as user - not their, fault.
So back in juli 2019, some guy or girl Engineer popped up, saying from this day we will Change That, without him or her knowing it would solve a claimed as unaware of problem.
Yes, Shuuuuuure!
The Dura-Ace model is Declared as the Flagship (read: more bucks) for Racers, with the Ultegra coming in second (read: less bucks) in the weight-cheating race.
If they also rank like this in the failure race, statistics by users, or easier, by Shimano of their crank recall are needed.
But since the latter decided to Keep Silent in september 2019, the expectations are probably grim.
Pay Shimano Pay!Release Date: March 16, 2026
WASHINGTON, D.C. – The U.S. Consumer Product Safety Commission (CPSC) is announcing that Shimano, Inc., of Japan, and Shimano North America Holding, Inc., of Irvine, California, have agreed to pay an $11.5 million civil penalty. The settlement, which has been provisionally accepted by CPSC, resolves CPSC’s charges that Shimano knowingly failed to immediately report to CPSC, as required by law, that its 11-Speed Bonded Hollowtech II Bicycle Cranksets, Models Ultegra FC-6800 and FC-R8000 and Dura-Ace FC-9000, FC-R9100, and FC-R9100P, contained a defect which could create a substantial product hazard or created an unreasonable risk of serious injury or death to consumers.
Between 2013 and 2022, Shimano received thousands of warranty claims relating to the bicycle cranksets and dozens of reports of consumers globally sustaining personal injuries while using the bicycle cranksets, including bone fractures, joint displacement, and lacerations, due to falls from bicycles, contact with the broken cranksets, and impact with the ground. During this time, Shimano, Inc. made nine overall manufacturing and design changes that resulted in over twenty-five individual changes to the bicycle cranksets to mitigate the potential for the cranksets to separate and break. Despite possessing information that reasonably supported the conclusion that the bicycle cranksets contained a defect which could create a substantial product hazard or created an unreasonable risk of serious injury or death, Shimano did not immediately report to the Commission.
I've concluded he doesn't like Shimano
February 15, 2025
Why Shimano Waited So Long for This Recall?
I honestly don’t know the answer to this question. It’s one of the things that’s strangest about this whole case.
This problem is not new. For example, there are dozens of failures on this Instagram page.
Shimano Ultegra crank with info to check out to determine the needed recall.This crank doesn’t have to be sent for inspection
And Shimano certainly has a lot of internal data on complaints. So the fact that they waited about 11 years to announce this recall is alarming, maybe even scandalous.
Why They Don’t Actually Recall ALL Cranks?
Another talking point is why Shimano will not replace all cranks where a potential problem may occur, but only the damaged ones. They say in their statement that all cranks will be inspected, but no further action will be required for those that pass inspection.
33 miles, 11 times the distance the TS here had to limp (here on the other/left leg).“The advice was just to listen out for any unusual creaking,” they said. “There’s nothing to see on mine — but the riders who’ve had their cranks fall apart probably thought that too. I’ve replaced it with 105 — you don’t enjoy or look forward to riding the bike with the knowledge that the fault is potentially there.”
Another, who shared this picture [below], was left limping 33 miles to the nearest train station, mostly on their left leg, but received a replacement crankset eight days after taking it to a bike shop, faster than the expected two weeks.
Shimano has brought up a new product in their production, especially as fail replacement.The new crank mechanism will be in a special version, which may differ slightly in appearance while maintaining the same parameters.
I have no glue what you mean. You probablyThat crank and bottle must be super special as they seem to be horizontal on a vertical piece of wood.
As I showed several times earlier in the thread: 20 grammes extra material in the spindles wall (thickness, towards the inside ofcourse), would have increased its resistence to torsion forces with 29%.@silva - please would you stick to Hollowtech 2 spindles and their fragility or not - that's the thread's topic, and not waste your and our time on crank arms some versions of which are subject to inspection/recall.
The inspection procedure for dealers:Enhanced Inspections: Shimano will (1) distribute a magnifying device with enhanced lighting to every Recall Retailer free of charge
But then we read (example this topic) about spindle breaks too, and clearly ALSO due to initiation of material defects, resulting in movement, resulting in fatigue.
