Snow/Ice advice urgently needed!
summerdays
Cycling in the sun
Bristol
Well Sam did you get home ok?
neslon
The Toon
shedloads here - sporadic blizzards since yesterday evening and forecast for more + ice for days. the conti ice claws go on tonight
See? "Sporting fixtures at risk include racing at Newcastle on Saturday, with Gosforth Park currently under 7ins (18cms) of snow"
Sam Kennedy
Newcastle
I got home fine :smile:
The roads which were un-cycleable were pretty clear, so I cycled the majority of the way home, then walked for the last 10 minutes where it was too icy/snowy. The main roads were fine apart from the odd chunk of ice.
I have *just* enough clearance for 28mm tyres, would it be worth putting those on and running them at 50 psi?
Sam Kennedy
Newcastle
I put my 28mm tyres on, and ran them at 70psi front / 80psi rear. Much more grip than yesterday! I was cycling on smooth ice and I only nearly fell off once!
I should be fine with these 28mm tyres for the winter, unless the ice gets even more slippery.
