mickle
innit
- 53.933606, -1.076131
Took Mrs Mickle's Thorn Tandem front wheel into my local this a.m. as it was making a godawful grunching noise which points to an internal fail of something. I trust their abilities more than my own in the area of hub internals. They've never worked on one before but I have every faith that if they do screw it up they'll make good.
So I've done a bit of reading up and can't believe some of the stuff I've found. It seems likely that I'll have to send it back to fricking Germany to have the bearings replaced. But get this: Early ones not only had to be sent back to the factory for bearing replacement but also had to have the spokes removed. WTF? Why would you go to the effort of designing - what they claim to be the best dynamo hub in the world - but not make it user, or at the very least, LBS serviceable?
Der.
Der.
