Globalti
Bottom headset bearings on carbon Specialized bikes are badly exposed to water thrown up by the front tyre and soon start to rust. You can pick them apart carefully, clean up and re-grease and eke out their life for quite a long time but I'd like to find a source of new that isn't at the extravagant Specialized dealer price of £60 a pair. And I don't need a pair either; just the bottom ones.
They are sealed cartridge bearings 7mm thick with a 45 degree chamfer on the underneath of the inner and the top of the outer race - I believe they are called angular contact bearings? On my 2013 Roubaix SL4 the bottom bearing has an outside diameter of 47mm and inside that measures 34.2mm. There is no alloy sleeve on the steerer; this bearing sits straight on a 45 degree shoulder on the carbon fork. I found a replacement at a good roadie shop without too much trouble. I believe this bearing is called a 1 1/4 inch bearing, which has nothing to do with the dimensions I've listed above.
On my son's 2013 Roubaix SL3 and my pal's 2013 Tarmac SL4, there is an alloy sleeve on the steerer, on which the bearing sits. This bearing measures 49mm outside diameter and I believe is called a 1 3/8 inch bearing. These are the ones I can't find - I've searched the web and visited five LBSs and have come to the conclusion that they are the cycling equivalent of hens' teeth, thanks to the popularity of that size.
Can anybody:
A) confirm that I'm right in calling them 1 1/4" and 1 3/8" ?
and
B) suggest a supplier?
Can anybody:
and
