How often does it happen? Once per wheel revolution? Once per pedal revolution? Other? Is it restricted to a particular gear? Does it happen when you freewheel? Does it only happen when pedaling really hard?
You've got a harp playing invisible leprechaun stuck in your spokes. They're notoriously tricky to get rid of. Pots of gold, and 'lucky charm' cereal work well.
No, about 8 months old, looks straight, between the brake blocks, I havent had it on a truing stand or anything. No obvious damage, no spokes seem looser than others.
if no access to bike stand, turn bike upside down and turn peddles/crank listen and watch closely could even be a tight chain link or mudguard to close to wheel (if fitted) check bolts for wheels in derailleur are tight good luck.
I have had a similar problem with a very old rear wheel. I have given up looking for a cause, but have consigned the wheel to my "emergency bike" that I only ride to the shops and back, when my others are out of commission. I would love to know if you find a cure.
