- London
I know this topic has threaded through one or two threads primarily on other subjects in the past, but I'm particularly interested in this.
Views/reasoned opinions, preferably from experience, of the relative merits of square taper and Octalink bottom brackets.
The bottom bracket will be used on a tourer using mountain bike type bits and gearing, so I'm not interested in the availability of road chainsets. The bike will be 8 or 9 speed so I also don't care about 10 speed and above etc.
My own experiences are from one bike with square taper, a Cannondale fast city bike with Octalink and a Dahon with I think ISIS, which I take to be a development of the Octalink principle.
The square taper bike lasted something between 10 and 15 years before I needed to change the bottom bracket. Well actually, a bike shop changed it as I'd been daft enough to not periodically extract it and grease the threads every year and couldn't get it out - now all sorted on that front. I think the original square taper had been some generic thing fitted by Ridgeback but it clearly did its job. The bike shop put a UN26 in (I understand the UN55 is better - can anyone also tell me why this might be?) and that is also going fine after a few years.
The Octalink in the Cannondale seemed to perform OK. Had to change it once but can't complain.
The ISIS in the Dahon was a piece of *** and had to be replaced after very little use. But always possible that that was not because of a probem with ISIS as such but down to Dahon's often dodgy parts sourcing - the old one turned out to be from some unrecognisable chinese company.
I rather thought that Octalink was on the way out but Shimano's relatively recent 9 speed Alivio uses Octalink.
Also, if you were travelling i some far flung places and needed a spare, which would be easier to get hold of?
Since Octalink is a relatively (I stress relatively) new idea and failed to dominate/take hold of/transform the components market I'm inclined to think square taper would win on this. But I thought I had better ask.
