Okay I've pretty much narrowed down my n+1 list to 2 MTBs (for the time being anyway.....);
Focus Whistler which has 27 speed Shimano Deore gears
Carrerra Kraken with 27 speed SRAM X5 gears.
I've never had SRAM gears before are these better / worse / just the same as Shimano?
Also would you go V-Brake or disc brakes in dusty/sandy/potholed/dry/crap roads? The cost of the Kraken is slightly more (as it hasn't been discounted as much as the Focus which has a higher retail price) but comes with disc brakes but I'm feeling more for the Focus.
Carrera Kraken;
Carrera Kraken;
- Frame Material: Aluminium
- Frame Size: 17-18
- Gears: 21+
- Gender: Mens
- Suspension: Front
- Alloy Rims: Yes
- Brake Type: Hydraulic Disc
- Chainset: Truvativ Isoflow
- Fork Lock-out : Yes
- Fork travel: 120mm
- Forks: Suntour XCR-D with Remote Lock-Out 30mm stanctions
- Forks - Adjustable damping : No
- Frame Colour: Black
- Frame-: 7005 aluminium frame with double butted main frame tube
- Front Brake: Tektro Auriga Comp - Wavy Rotors, 180mm
- Front Mech: Sram X5
- Gear Shifters: Sram X5 Trigger
- Handle Bars: Kalloy Oversized - Matt Black
- Headset: Semi-Intergrated - Black
- Hubs: Formula DC-20
- Number of Gears: 27
- Pedals: Wellgo - alloy platform BMX style
- Quick Release Wheels: Yes
- Rear Brake: Tektro Auriga Comp - Wavy Rotors, 160mm
- Rear Mech: Sram X5
- Rear Shock: NA (rigid)
- Rear Shock Adjustable Damping: NA (rigid)
- Rear Shock Lock-out : NA (rigid)
- Rims: Strongarm DDM-1, double walled with eyelets
- Saddle: Carrera
- Seatpost: Kalloy SP-602 micro-adjust
- Stem: Kalloy Oversized -Matt Black
- Tyre size: 2.1
- Tyres: Continental Speed King
- Wheel size: 26"
- Frame Aluminium 6061, zero stack frame
- Fork Suntour XCT V2-MLO Lockout 80mm
- Rims Black Comp, double wall, aluminium 19-559
- Front Hub Shimano Deore, QR
- Rear Hub Shimano Deore, QR
- Tyres Schwalbe Smart Sam 54-559 (2.1)
- Cassette Shimano Deore 9 speed, 11-32T
- Crankset FSA MTB CK-306, 44/32/22T
- Bottom Bracket Sealed bearing
- Shift Levers Shimano Deore, Black
- Rear Derailleur Shimano Deore, Black
- Front Derailleur Shimano Deore
- Chain KMC
- Brakes Shimano V-Brake
- Stem Black Comp, Ahead
- Handlebars Black Comp Flatbar
- Saddle Concept SL MTB
- Seat Post Black Comp
