U
User6179
My Steerer is worn where the split ring sits above the top bearing.
Greased and put back together but still some play in the forks.
I am wondering if once you get this type of wear does it then become impossible to get the play out of the forks and because you cant get the play out then this in turn increases the wear?
This is a pic off the internet to illustrate the problem, note my steerer is metal not carbon.
