Summer clothing (tops)
Shoxt3r
Hi all,
I've had my shirt and (running) shorts for quite a while now but with the hot weather finally here I need a replacement shirt. The one I have at the moment is completely unsuitable (winter thermal, though it does seem to wick the sweat off quite a bit!).
I usually wear a sleeveless reflector vest on top but that seems pretty breezy without flapping around too much either.
https://www.mountainwarehouse.com/talus-mens-short-sleeved-round-neck-top-p13067.aspx/
Thoughts? Ideally something relatively inexpensive would be good. Thanks in advance!
The description makes it sound like a winter base layer?
  • IsoTherm - Our IsoTherm technical fabric has heat retention technology, perfect for insulating your body heat in colder climates
get a summer cycling jersey with reflectives ? Or a running top?
CanucksTraveller
Hertfordshire
If you're not into the whole aero or cycling specific thing, just wear gym / athletic tops. I wear Adidas basics tops, they wick well, they look decent, and they're cheap.
Boardman cycling shirts are fine, I've got one. Sizing comes up a bit big.
London
Hi all,
Cripes, thermals in this weather.
Emergency action needed.
Pop over to findabargain and check out my recommendation of that aldi short sleeved top.
I thought you folk back there were supposed to be having a heat wave. My recommendation:
steveindenmark
Any quick dry T shirt will do.
As for a reflective top. Look in Halfords for a zip up motorcycle reflective jacket with elasticated sides. They dont flap about like the bike ones.
Cycleops
Accra, Ghana
Really, @FrankCrank how could you? Yellow and orange :laugh:
Regarding the question any synthetic cycling top should wick well. I get mine from the secondhand market here so maybe look on eBay.
Or if you want new Decathlon do a mesh technical breathable t shirt for seven quid:
https://www.decathlon.co.uk/p/men-s...t-500/_/R-p-327429?mc=8606556&c=YELLOW_ORANGE
Or this cycling ‘lifestyle’ top for rather more:
https://www.decathlon.co.uk/p/briga...ection-t-shirt-grey/_/R-p-X8674077?mc=8674077
S
Shoxt3r
Are you riding in the dark ? If not don't bother with reflectives.
I'm usually riding in early evening/dusk so once I have this jersey I'll probably ditch the reflector jacket until it cools right down again, then swap back to that with thermals
