biggs682
- Northamptonshire
oh dear not a good day then
'chain suck' surely?chain wrap can mean a slip or jump when you push donw on the pedals
Wear is also a serious consideration with small rear cogs off road. I've destroyed a 14T in three months. 18T similar level of use still going stong.it's the amount of the sprocket and chainring the chain engages with, so if you have a tensioner that pushes the chain up then more teeth will be in use than with one that pushes the chain down. Makes a far greater difference at the back than the front.
Also cog/ring selection makes a difference, 48x18 gives roughly the same gear as 34x13, but clearly more teeth are engaged with the chain using 48x18. Offroad singlespeeders may go with the smaller combo to gain extra ground clearance.
Even with my new chain tensioner, the chain still jumped, especially going up hills.
Discovered that the cause was the new 1/8 chain I had fitted a few weeks ago.
Replaced it with my old 3/32 chain, problem solved at last!
