Tea?
Bobby Mhor
Behind You
Still a light in the windows at night, to guide those lost?
I'll not disagree on surprise visitors. Especially those bearing gifts...
Yer gills get a well earned clean. Dry here, so far, but expecting a damp evening-night.
You're headed over Moville a fair bit o'late. You tried one of those McD's that are in the motorway services yet.
Stuck trying to get One across...
Do the Saturday crosswords only. A week before they give the answers. If they want yer patronage, it'll have to be with a discount, for yer loyalty.
Any acks on this "Meshtastic Route"
And you keeping a firm hold of it as you hold it out the window.
Actual size....
I was going to use a long-handled teaspoon just for fun...
No 'acks' today but tbh didn't expect any on the 'out'..
We played 'right or left?'... right, right, right won..
Normally, that way is left, straight on, then for a fair bit then turn round...
Still would prefer the bigger 40cm antenna..( that one is 20cm)
The problem is antenna diameter( Bottom) is too big for the allocated fit, I must learn how to adapt it.
Built for urban use tbh.
classic33
Leg End Member
Actual size....
Smaller than I were expecting, and neater in overall design. The yellow case the work of yer overworked printer?
T'is teaspoon then...
Heads left, Tails right next time. Take yer route planning to a the toss of a coin.
Would a wraparound antenna work? Is one even available that'd wrap round the edge of the case.
Question on antenna's.
Are the threads common ones throughout or do they vary by manufacturer.
Looking at replacing an old mobile phone one, then getting the inside swapped out for a new one.
