jonny jeez
- Chislehurst, Kent, UK
The cables had stretched and on a ride over crystal palace on wednesday I couldnt find the lowest gear...it just bounced about a lot.What were you working on just prior to stuffing them up and what was the reason for you trying to adjust the gears?
I wasn't fettling with anything prior to attacking this though...it was a dedicated mission.
one tiny point though.
Inside the adjuster barrel was a tiny cylindrical washer/grommet, it came loose when I adjusted the barrel fully in (the barrel kind of pushed it out) from the retainer bolt side of the barrel (ip stream from the cable) and is now hanging around between the barrel and the bolt... hanging on the cable.
I cant see if it fits into the barrel end of the bracket or the cable/bolt end.
