Temporary Light Timings
BrynCP
Hull
Had a bit of trouble today with my ride.
Hit some temporary traffic lights at some roadworks, which had closed one lane of the road. As I approached it turned from red, to green, and I cycled through, no traffic behind me as it's a quiet village road. However, I think it then went to red and the other side green before I got through. Bear in mind I was cycling around 17mph and this is a 20mph road, this just seems like poorly timed lights?
The problem I had though, is the driver at the front of the queue at the other side saw his green light and moved out and right in front of me and refused to move, I literally had nowhere to go other than dismount, and get up onto the narrow pavement.
The driver is clearly in the wrong (green means go if clear) but should there be a minimum time on the lights to allow slower road users through without intimidation?
U
User33236
If the driver saw his light go to green why it he clearly in the wrong? Likely another motoring thread at present going on about a cyclist jumping a red light as this is likely what the driver would be thinking.
Back to timing. I have noticed some set of temporary lights not even giving enough time for cars to clear so no idea how the timings are worked out.
U
User33236
That would then give a speed of 10m/s or 22.37mph which exceed the speed limit of the road the OP mentions.
I think the 5 seconds for 50 metres is just a general guide for contractors as further down it does say if vehicles are still in the shuttle lane when the next green starts then the red is too short which is what the OP reckoned.
