Landsurfer
Thats the whole point of the post .... did you not read the OP .... the flattest route through Devon .... thats not a flat route .....
Depends what type of roads you want to ride on. A30 will be flattest but I presume you don't want to do that.Having done LEJOG , and doing JOGLE next summer can anyone recommend the flattest route from Surton Cross to Lands End please... Mileage is not an issue just the flattest, easiest route ..... please ...
We .. ok I .... struggled heading north last year on the LEJOG ...
Flattest non-A30 is probably Sourton Cross -Launceston - Camelford - Wadebridge - St Columb Major - Redruth - Hayle - Penzance - LE
As a benchmark, the A30 all the way is 150km + 1721m.No matter what else I tried, I could never get Sourton-LE below 2000m ascent and max 7.8%.
I've looked at Richard's route to Okehampton (Sourton Cross) and reversed it.Here's the flattest route for LEJOG in general I've been able to come up with: https://cycle.travel/map/journey/33522 . . .in Cornwall or Devon . . you could nick that section and then go your own way.
I have just looked at that RidewithGPS route too and agree that it is a good (ie.interesting, quiet roads) route as well as a flatter one. Up to Bodmin Moor anyway, haven't cycled the rest of it.I've looked at Richard's route to Okehampton (Sourton Cross) and reversed it.
https://ridewithgps.com/routes/31670065
Comes out at 185km + 2019m - some lovely roads but significantly more climb (and 20km longer).
Richard - you might be interested in this topo map:
https://en-gb.topographic-map.com/maps/b9/England/
For the avoidance of doubt, it's not flatter. @nickyboy 's suggestion ("Flattest non-A30 is probably Sourton Cross -Launceston - Camelford - Wadebridge - St Columb Major - Redruth - Hayle - Penzance - Land's End") is 280m less climb (but does spend a fair time on the A39, which is a perfectly good road to cycle on (ime and imo)).as well as a flatter one
I don't see how you're arriving at those numbers without some long lengths of A road.As a benchmark, the A30 all the way is 150km + 1721m.
My first stab at this is the same as @nickyboy: that comes to 162km + 1749m (so 'flatter' than A30 route). And about the same if one heads SW from Camborne via Marazion. In reverse, that's roughly the route I took on Day 1, but stayed 'high' (ENE) after Davidstow and took a straighter line via Holsworthy towards Hatherleigh (first night).
Going south about via North Brentor, Callington, Liskeard, (SW of) Bodmin, old A30 line, Goonhavern, before picking up the Scorrier, Redruth etc roads, comes up as 166km + 1793m.
At a glance, the two seem to differ slightly in some places, including the RWGPS doing laps of Land's End. Enough to explain much climbing? I don't know.I've looked at Richard's route to Okehampton (Sourton Cross) and reversed it.
My error for the short (?500m) extra lap. But that area around the LE 'attraction' parking is dead flat, as you may remember. So close to zero extra metres.the RWGPS doing laps of Land's End. Enough to explain much climbing?
OP asked for the flattest route; A roads (other than staying off the dualled A30 like any sane rider) not an issue.I don't see how you're arriving at those numbers without some long lengths of A road.
Think you can shave another 200ft of climbing off by staying north to HayleOP asked for the flattest route; A roads (other than staying off the dualled A30 like any sane rider) not an issue.
As I said: "does spend a fair time on the A39, which is a perfectly good road to cycle on"
https://ridewithgps.com/routes/31686068
163km + 1714m
40km on the A39 and some on the quiet A road into Newquay and then some on the A3075 to Scorrier. Depends on whether you want to 'get it done' or want to wiggle around (and up and down) after 'X' days on the road.
The last 90km is my Day 1 route in reverse, but I then went up to Padstow and across the ferry to Rock. Last year I rode almost exactly the route linked back from Penzance, through Sourton Cross and then down the old A30 to East Devon (210km).
I get the same climb both ways (from Camborne station to Penzance station either via Connor Downs/Hayle or via Leedstown): 151m. Latter route also avoids the stretch on the A30 (Hayle to Longrock).Think you can shave another 200ft of climbing off by staying north [of] Hayle
