Things some idiot got wrong and now can't be put right
Profpointy
View attachment 353076 before I plug my guitar in is this right
That would actually work if you've still got and old fashioned fuse box. I recommend you don't try it though.
I did hear of a beauty where someone had a complete socket circuit installed which hadn't actually been wired in or was on a blown cirtuit. Temporary fix was a wire with a plug on both ends; one plug into a working socket, and other end into the unconnected circuit. Voila, other set of sockets now work Problem was when the other circuit was fixe, and the extra plug removed. You now have a wire with a plug on the end where the exposed pins are live. A wonder no one was killed but I believe someone had a belt off it.
swansonj
Neutral is very close to earth so effectively neutral = 0v and live = 0-230v
Neutral is very close to earth and can indeed be regarded as being at 0 V. But the phase wire (colloquially and pretty universally called the live wire) goes from 0 up to 325 V, back through 0, down to 325 V the other way, back to 0, and repeat every fiftieth of a second. 230 gets into the act because it's the average of that variation (using one particular averaging method) - it kind of makes sense that the average has to be less than the maximum.
subaqua
What’s the point
Leytonstone
Shall we really confuse people with phases being 120 degrees apart and other elastictrickery stuff like why it's the r.m.s value .....
  • Like
Reactions: mjr
Profpointy
swan beat me to it.
Earth is only 0V because that's what we choose to measure other voltages against ie we define 0V to be Earth for the purposes we're discussing rather than it being a measure. Voltage is potential difference rather than absolute
subaqua
What’s the point
Leytonstone
Try broken neutrals on the DNO network . And wondering why on a 230V system there are voltages in excess of 400V and in excess of 50A flowing in the main protective conductor . I know why BTW. It's just very strange when it happens and defies logic
Profpointy
I was trying to debug some mains wiring with my high input impedance multimeter and I was getting all sorts of quite high voltages on so say neatral wires. I kind of understand why, but confused me for a bit.
subaqua
What’s the point
Leytonstone
swan beat me to it.
Neutral is " zero" as in the U.K. LV distribution system the star point is legally required to be referenced to Earth .
ESQCR 2002 Reg 8 clause 3 (b) yes I am sad enough to know that.
subaqua
What’s the point
Leytonstone
If the " N" is not connected you are measuring a " L" conductor
