Mr Celine
Discordian
- Waxing my moustache
UK mains voltage: 650v peak to peak.
325v peak
230v root mean square.
https://en.m.wikipedia.org/wiki/Root_mean_square
Isn't UK mains voltage still in reality 240V? (Nominally 230V -6% / +10%)
325v peak
It is still really 240v as you say but I measure mine almost daily at work at it's dropped closer to 230v than it was when it used to be quoted as 240v.Isn't UK mains voltage still in reality 240V? (Nominally 230V -6% / +10%)
On my Pre-amp advice from Quad is that if there is a hum through the system one thing to try is to swap live and neutral over in the plug as this can solve it.OK, can somebody explain what the actual difference is between live and neutral? I mean it's alternating current so they must be the same and just swap over fifty times a second right? Right?
It doesn't matter - IF you have a system that is designed for not mattering. We have a system that is designed for them being the right way round - single pole switching and fused plugs - and it very much does matter with our system to get blue and brown the right way round.
Not all were though.View attachment 353170
(I post with trepidation - but back in the day when it was possible, and made sense, to rewire a plug rather than spend £1.49 on a new cable and plug combo like that one I was really quite wary about wiring up twin-core plugs with that sort of connector. Until I realised that all my care was wasted because the connector was symmetrical.)
I'm colour blind so all my plugs are a sort of smoky charred smelly plastic black colour .
Yellow is going round the Green in the wrong direction.When wiring plugs I go to the Hawkwind section of my record collection for a handy aide memoire.
If that doesn't work, try drawing round the edges of your cd with a green marker penOn my Pre-amp advice from Quad is that if there is a hum through the system one thing to try is to swap live and neutral over in the plug as this can solve it.
Also the Poweramps pick up mains from the back of the Pre-amp (control unit) with a 2 prong connector which can be inserted either way up (Earth is provided by the signal lead to reduce 'Earth Loop Hum' which can occur with multiple wires)
Will that stop the needle skating off them.If that doesn't work, try drawing round the edges of your cd with a green marker pen
