DCBassman
- The lumpy far South West
And wanting a little more comfort.
Want to go to 28s, will they fit, do you think?
Edit: 23s currently fitted.
If you do decide to turn them the other way, check that the left shoe is on the left side. Don't want them pushed out when you apply the brakes.Oh, entirely likely. But I just copied what was on there when replacing!
They wouldn’t work for so long if you simply turned them the right way up like others suggested.Whatever, they work!
They'd allow slightly lower pressures. A couple psi missing can make the difference between rattling teeth and gliding over rougher tarmac but potholes etc would still be a problem.Will check more closely later. Don't suppose 25s would be that much different?
