Nigeyy
- Massachusetts, USA
Well, look, people don't commute on full sussers for a reason: they usually suck up a lot of energy. While there are designs out there that reduce pedal bob considerably (e.g. Giant Trance/Anthem), they are tad more than $85. And even then, I'm not sure they are the best for commuting even then.
Having said that.... if you have a bad back, a quick and relatively cheap potential solution could be bigger fatter tyres to soak up the bumps, as well as seatpost suspension (this is assuming you stand on the pedals as much as you can going over big bumps already and you still need something more). You may also want to try experimenting changing your riding position too. But just to be naysayer as well, you can commute on a full suspension bike (e.g. I have to ride my full suspension on the road to get to an off road circuit), and even a really cheap one. Yes, you'll be using much more energy and the bike may weigh a ton, but if it keeps you cycling (albeit more slowly) go for it.
