You've gone from no difference to no negligible difference - make up your mind.
Let's say no measurable difference. Does that work for you?
I'll assume you are right, and this will save you 4 seconds over 10miles. But there is no time trial course where you would stay in a 1:1 gear for the whole course. Let's be generous and say you're in that gear for 5% of the time. So choosing the optimal gear will save you .... 0.2 seconds. According to google, the 10 mile TT is recorded in whole seconds, so even assuming time keeping is 100% accurate, then 4 times out of 5 that saving will make no difference (eg 18:05.1 and 18:05.3 would both be recorded as 18:05). But no time keeping is 100% accurate. According to
this, the precision of a TT is only 10ths of a second, so it'a accuracy can only be 0.05 seconds at best and probably much greater, so the timing can probably not accurately record a 1/5th of a second difference.
But it doesn't need to. Apparently the national record was
smashed last year by 45 seconds, and the second guy in that event also beat the record, so these guys are not pissing about with 0.2 second tweaks.
And for anything outside a time trial with electronic timing, 0.2 seconds is not measurable. You can't start strava, your garmin, your cycle computer, a stop watch with anywhere near that accuracy.
So yes, picking one gear over another may make you quicker, but only God will know it. Hence, "negligible"
