Cubist
Still wavin'
- Ovver 'thill
Anyone able to recommend one of these fine little fellas?
kyuss said:I see EBC have their own version of the Topeak. Looks very similar.
There's also the gorgeous looking Lezyne HPG if you fancy saving a bit of weight. Anyone got one of these? I quite fancy one.
It's not hard to replicate that effect by using a conventional pump and bracing the end against the log or bollard that you've leant your wheel on.Randochap said:Interesting. Seems like Topeak's design is catching on as people realize it's much easier to push against the ground than hold a pump in mid-air and lever against one's own arm.
