Trek FS new drive train recommendations needed
phil-b
west wales
The gearing on my old Trek FX is very worn. I was thinking about replacing the 3x8 drive train with a 1x
A shimano cues 1x9 would do the job but should I go for something more premium and maybe 1x11
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
The hearing?
phil-b
phil-b
west wales
CUES would be fine ! But you'll need the groupset if you have integrated shifters/brake levers
I swapped out the integrated shifter/break leavers already and added hydraulic breaks but I will still need to replace the shifter to accommodate the extra rear gears and also cues has a different pull ratio to older shimano stuff
phil-b
phil-b
west wales
Would a 11 SPD fit the freehub have? I thought they only went to 10 speed 11 speed + are different.
I’m going to have to check this carefully . For some reason I assumed an 11 speed would fit. Apparently some will fit some won’t . I guess the safe bet is to stick with 9 or 10 speed.
