Triban 3 red
Nightjar
Hello I've purchased fulcrum 900 700c wheelset for triban 3 red 54cm would a shimano 8 speed cassette be suitable
Cycleops
Accra, Ghana
What speed set up is on the Triban? If it's 8 speed you should be okay if you're using the same cassette. If not check the mech can handle the range. Make sure they are for QR and not TA.
You'll probably have to retune the derailleur.
By the way :welcome: to CC.
N
Nightjar
Thanks that's good to know I'have to admit to being a dinosaur last cycle was raleigh medale off to evans Monday morning
Jenkins
Felixstowe
The Triban 3 was originally sold with what is now Shimano Claris (2303 I think it was when it came out) which was an 8 speed cassette and a triple chainset so, as long as the previous owner hasn't changed anything, a Shimano compatible cassette is the correct fitting. You may need a spacer to go behing the cassette though.
