Sh4rkyBloke
Jaffa Cake monster
- Manchester, UK
You do work, on here?? Wow, I come here to avoid doing work!Cubist said:My work here is done......
Cyclist33 said:The rules also say you must have pedal reflectors and a rear reflector but most people don't.
al78 said:Incorrect.
The rules say you must have pedal reflectors and a red rear reflector if you are riding during lighting up times.
vbc said:Quite a lot of response to my original post!
Not particularly proud about having a go at the bloke but, like increased aggressive behaiviour towards cyclist on the road, pedestrians now suffer intimidation from road users who consider themselves further up the 'food chain'. So now you have pavements routinely used as car parks (with no objection from the police), cars & vans driving on pavements to get past traffic queues and as defacto cycle paths, whether designated as such or not. Cyclists have to be assertive on the road and pedestrians some times have to be assertive on the pavement.
Just sick and tired of being a target, whether I'm walking or cycling and feel justified in forcibly pointing out to the scrote that he was in the wrong.
And by the way, I cycle on the pavement when I'm riding my bike to work. In the first place where I join the busy A38 on an uphill slope and use a short stretch of pavement to get up to speed before joining the carriageway - seldom any pedestrians and will always slow down/give way if there are. In the second place, on a shared use cycle path to avoid a dangerous stretch of road.
mangaman said:I'd shout "Tosser" at you if you cycled up the pavement near the A38 as well![]()
summerdays said:I even admit to occasionally cycling on the pavement just beside the A38 - for 4 m if that ... I want to turn right onto the A38 and then immediately 4 m later right off the A38 at a busy junction... instead I cycle on the pavement if winter, or on the grass beside in the winter time. And that particular bit I notice loads of cyclists doing the same... I have even requested that they put in a path/cycle path on the grass were there is a clear line showing how well the route across the grass is used ... about 400m long - note no pavement for the pedestrians on that side of the road at all.
There are parts of the A38 around here which are shared use (OK currently they are being dug up - surely that set of roadworks must be finished soon), and you would definitely meet more cyclists than pedestrians on them. So it probably depends on where vbc joins the A38 ... I'm still trying to work out where there is an uphill slope going inwards towards town...(lots of assumptions there) ... if its the one I think it could be then the pavements are more than wide enough at that point, but I'm really not sure where he is on about.
There are differences in how people can cycle on the pavement... some bits of pavement are wide and not really used by pedestrians whereas there are bits of the A38 for example near the old swimming baths on which there is so much shop over-spill onto the pavements, pedestrians etc that you would be mad to try and cycle on the pavement.
