Muddyfox
- Blackdown Hills Devon
I have Sram Triggers on my mountain bike and Shimano Triggers on my touring bike ... but i would happily swap both for Sram X0 gripshift
Ohh my mistake.Reply was meant for Salad Dodger, however if you're having the same trouble can I suggest lubricating the cable and checking the plastic guide under the bottom bracket which can get gunked up with mud sprayed up by the front wheel.![]()
Yes the Revoshift are the ones fitted to my bike as i will be using mine for road use its not a problem.Replaced the revoshift on my old MTB with triggers in the winter, let's just say I'll never ever go back to twist grips.
Twisters are just about ok on the road but off road when it gets a bit sketchy they literally tie themselves and your hands in knots.
Hi Rickshaw Phil.Reply was meant for Salad Dodger, however if you're having the same trouble can I suggest lubricating the cable and checking the plastic guide under the bottom bracket which can get gunked up with mud sprayed up by the front wheel.![]()
Make the most of being able to pull away in 50x11 there will come a time when the lowest gear isn't low enough.Two things have conspired against me lately. Firstly, when riding fixed I don't have gears so I sometimes forget to change down when stopping on a geared bike. Secondly, I seem to be able to start in higher gears these days so sometimes don't change down enough. It's all good fun, except when I completely forgot to change down at all and had to pull away in 50x11!
Nooooooooooooooooooooooooooooooo!Make the most of being able to pull away in 50x11 there will come a time when the lowest gear isn't low enough.![]()
Hmmm, if it's been like that from new the possibilities I can think of are that the cable runs aren't ideal or possibly one or more of the outer cable ends haven't been opened up properly after being cut to size. These would both be things set up by the factory rather than the bike shop (bikes arrive at the shop mostly built up, just needing final assembly and adjustment).Hi Rickshaw Phil.
The bike is now at my daughter's flat a couple of hours away from me, so I can't be sure. The gears are certainly Shimano cheapest version (Altus????) and I think the shifters were Revoshift, but can't be certain.
The bike was bought new from a "proper" bike shop - not a supermarket special - so I would imagine the shifters were all correctly set up but they always felt quite stiff to use, even from day one. Not ridiculously so, but they always felt to me harder work than the trigger shifters on my bike. But my daughter preferred the twistgrip shifters, as she was a terror for stopping in way the wrong gear, and could then "crash" down through the gears to find something easier to start off in. She never seems to have got her head round changing down as you coast to a stop, in readiness for pulling away again.
