to CycleChat.The Reliant engine was actually based on the Austin 7 engine, first produced in 1922. That's way before BL came into existence.It's a basic 850cc old school BL engine.
Or it maybe a fire breathing 1000!!!
So a few of us will be able to give you pointers..
Points coil distibutor carb and lovely easy to maintain engine
The Reliant engine was actually based on the Austin 7 engine, first produced in 1922. That's way before BL came into existence.![]()
Is it really that old..still a lovely basic engine
Yes, the basic design is.
Reliant did refine it over the years and then produced their own improved engine at 850cc, but it's lineage can be traced directly back to the early 1920s.
The bottom ends might have been the same - the Austin was a side valve and the Reliant OHV.The Reliant engine was actually based on the Austin 7 engine, first produced in 1922. That's way before BL came into existence.![]()
The original Reliant engines were side valve. As I said previously, Reliant refined the engine over the years and finally developed their own 850 cc engine which was ohv.The bottom ends might have been the same - the Austin was a side valve and the Reliant OHV.
everything is interesting in a Robin!!A pal of mine had a Robin, he's an active member of a mine exploration group and cave rescue. Quite a lot of meets are up farm tracks, which can be interesting in a car with a single wheel up front.
