TTTT! (Time Trial Tandem Trike)
Hampshire
Couple of friends of mine have just had this built, they already hold a few tandem and tandem trike TT records and have decided to really go for it this summer.
572264
(yes, we have pointed out the stoker's seating arrangement looks very uncomfortable and the lack of pedals will limit the power output)
Sharky
Kent
Very nice. I'd be happy riding that.
Ian H
Ancient randonneur
I might worry about how those wheels cope with sideways forces. The end-to-End record is ripe for updating.
Milkfloat
An Peanut
Midlands
Wowsers, that looks very interesting. At the speed they will be travelling I would have thought some rear brakes might have been of use.
Anthony.R.Brown
I think you need to ditch that design and go for the Comfort model :smile:
580111
T4tomo
looks awesome, given how reputedly twitchy trikes are to ride, I wouldnt be happy on it, better left to the experts at the speeds that should be capable of...
Trikes aren't twitchy.
What catches people out is they react the opposite way to bikes due to changes of your CoG.
If you lean right on a bike and then it turns right.
But if you lean right on a trike then it tries to turn left.
Plus on a bike you tend to lean then steer enough to correct the lean.
On a trike you need to get used to steering first then leaning to correct your balance.
Once that's second nature then trikes are easy to ride.
Luck ........... ^_^
biggs682
Northamptonshire
A tandem with equally matched riders are like a rocket and capable of good speeds and that one looks awesome
Never ridden a trike so can't comment but it looks good
Anthony.R.Brown
So what I want to know is...are all Tandem 3 wheel Trikes allowed ? any configuration ? like 2 wheels at the back or front ?
If they are then I am using the one below,it must be a Record breaker! :smile:
580690
Ian H
Ancient randonneur
Standard CCT regs apply, so no recumbents. Not sure about two wheels at the front.
Ian H
Ancient randonneur
I just listened to a second story of the front wheel of a tandem trike collapsing at speed on a corner. Pretty gory.
