Boondoggle
Regular
- York
Hi all, I was wondering if I could get some advice here. I've just begun cycling after many years break and have developed an issue with inner tubes. After replacing the rear one it popped as I inflated it. Later on the front did the same. Both have holes fairly close to the valve stem, about 2 cm from the stem in fact. I can't find anything inside the rim that could cause this. Any ideas ?? With the rear one I had added a few rounds of electrical tape over the spoke heads in case that was the problem, but it just popped again. HELP!!!
