Tyre advice
Fog Beast
Regular
Hi all. I just purchased a bike for my daily commute but discovered that there is an easier route. Problem now is that I have bought a road bike and part of the better route is on gravel. Would I be able to put some bigger tyres on to cope with this? How do I find out what size tyres the frame will take?
Or of course do I accept the mistake and take the road route? (Rather not as it adds about 30 minotes to the journey).
Loch side.
Yes, you will be fine. Obviously wider tyres will improve your comfort but you'll have to experiment or eyeball how much wider you can go.
If you think roadbikes are not capable of gravel, Google Paris-Roubaix race. Fasten your seatbelt before doing so.
Fog Beast
Fog Beast
Regular
Thanks for the advice. I will try a couple of different tyre types.
andyfraser
Bristol
I'd be interested in this too. Part of my new commute could be on an unpaved track (NCN 45). I'd normally use my hybrid with 28mm or 32mm tyres. I was thinking of putting 28s on my single speed for this route. I wouldn't dream of taking my road bike down there but it sounds like it could be possible.
John the Monkey
Frivolous Cyclist
Crewe
Pressure's a bigger factor than size per se, ime, as is the size of the aggregate (larger is trickier)
High pressure tyres will feel twitchy and squirmy as they ping stones out from under. It's rideable, but you'll need to pick a line more carefully & slow down a bit. Be disciplined about cleaning the bike & drivetrain too.
HorTs
Portsmouth
As I always do when it comes to type recommendations I will suggest any of the Schwalbe Plus range. Probably the Durano or the Marathon for this situation, the Marathons likely to be a better choice due to the gravel. They are my preferred options because I will always favour puncture protection.
John the Monkey
Frivolous Cyclist
Crewe
Wouldn't the casings be a bit stiff? I can imagine a similar problem to that of a tyre with high pressure, in terms of handling. (I do have M+ on one of my bikes, but it's been used on road only).
Boon 51
Deal. Kent.
In most cases puncture protection comes with a stiffer and heavier and a tad slower tyre but that's the way it is.. Marathon's are very good I prefer the 28cc over the 32cc but have a look at Kenda Block Eight's also.
Or Gatoskin's 28cc which is more of a road tyre but still tough and I run mine on 5 bar not 6 or 8 bar for more comfort.
