Tyre pressure...
icowden
Surrey
HI All,
I ride a Tern Joe with Schwalbe Big Bentyres. Now the tyres say that they are 35 to 70Psi.
The question is, where in that range is the "right" point to inflate them to?
Is it just down to personal preference?
I tend to inflate to 60Psi as I'm a bit afraid of going near 70....!
mjr
Basically personal preference (within some limits, harder is faster on smooth ground but less comfortable), but a starting point can be worked out from the manufacturer markings, tyre width and bike+rider+luggage weight by https://www.compasscycle.com/wp-content/uploads/2015/03/BQTireDrop.pdf or http://www.dorkypantsr.us/bike-tire-pressure-calculator.html
icowden
icowden
Surrey
Thanks folks. Those calculators tend not to work too well as the Big Bens are 40mm balloon tyres (apparently!).
60psi does feel about right. When they drop down to 40 you can really feel the increased friction.
Should I be worried about trying 70psi or is the upper limit well within the tolerance of the tyre?
ianrauk
Tattooed Beat Messiah
It's well within the tolerance, they are only a guide, they can take much more.
If I’m on mostly loose stuff, I’ll aim for the lower pressure end, if it’s light trails / tarmac, I’ll aim for the higher end of the pressure range. I regularly run my off roaders at 60 psi, and at 35 psi. I don’t see any point in going right up to the higher limits, 60 psi is fine for just about anything on road.
byegad
NE England
You'd be fine at 70psi. I'm not familiar with Big Bens but use Big Apples with similar upper a d lower limits. They're fine at 70psi and slower the lower you go.
Cycleops
Accra, Ghana
All down to the surface(s) you're running on.
I have 40c Schwalbe Tyraccos and are perfect on tarmac at 65/70psi but tend to dig in on the loose surface tracks down here.
