Juan Kog
permanently grumpy
Ah so that’s why my Garmin has a temperature display .I get my thermometer out before every ride and adjust pressures
For the most part I'm not too bad. If the road surface gets a bit iffy though then yeah there is that.
I was also on a long decline on the day of my accident. It was a long straight & I was going all out for me to see if I could tip 40mph as hadn't done it before (usually max out about 35-38). As I hit the 40 marker the bike certainly got all wibbly-wobbly.
Now i'm not sure if that's the tyre pressure playing its part, rider (in)experience, whether the bike itself or the gears can't handle that speed or what. Perhaps a combination of the lot. It didn't feel great that's for sure so I had to ease off.
"Many cyclists who have experienced a speed wobble report that pressing a knee against the top tube, or gripping it with both as you rise [less than a cm] off the saddle, cures it."see if I could tip 40mph as hadn't done it before (usually max out about 35-38). As I hit the 40 marker the bike certainly got all wibbly-wobbly.
To which I'd add: loosen any 'deathgrip' on the handlebars: let them wobble a bit.
Job Brandt's take, with John Allen's disagreement (and a video): https://www.sheldonbrown.com/brandt/shimmy.html
Yep, don't death grip it,
I weigh about the same as you, OP, and use 45 front and 50 rear in my 35c tyres. The ride is still poor because I allowed myself to be persuaded to fit Marathon plus! The flippin' things just won't wear out either!
It's interesting that Track cycles are still specified to have 119psi at Manchester Velodrome.
http://www.nationalcyclingcentre.com/track/information/track-bike-specification/
The recommended track 119psi, indicates to me that if UK roads were smooth (very unlikely), 119psi would be recommended on roads too, when using 21 to 25mm tyres. Therefore, we just need better roads, not less psi.I run 110 psi on my turbo tyres. They rarely hit pot holes on Zwift
The recommended track 119psi, indicates to me that if UK roads were smooth (very unlikely), 119psi would be recommended on roads too, when using 21 to 25mm tyres. Therefore, we just need better roads, not less psi.![]()
They're using old used car tyres now in road surfaces. So, getting the extra spring won't be a problem.The boards used in the track have a natural spring in them and are nicely smoothed. I suppose if the roads were made of wood…
They're using old used car tyres now in road surfaces. So, getting the extra spring won't be a problem.![]()
