CO2 cartridge and small pump for emergencies.Hi,
So lesson learned after getting a puncture miles from home :-( . So my small saddle bag now contains a spare inner tube and spanners. What else do you guys carry around? What do you guys do for a 'non large' bike pump?
Matt
No idea about foam but I have CO2 canisters on all my bikes and they all have presta valves. You just need an adaptor and off you go. It inflates them to a decent pressure in seconds. I carry a mini pump too in case of 2nd puncture but never needed it in tens of thousands of miles cycling.I may be wrong, I asked about the CO2 pumps or the foam ones but the man in the shop said that my tyre valve was too small for those. Maybe he just meant the foam because you wouldn't be able to get the stuff through such a small hole?
Do you have a better shop you can try?I may be wrong, I asked about the CO2 pumps or the foam ones but the man in the shop said that my tyre valve was too small for those. Maybe he just meant the foam because you wouldn't be able to get the stuff through such a small hole?
Wheel might not be aligned. Squeeze the brakes a few times. On the wheel where you locked it back up you can unscrew/screw each side to adjust it's positionThanks. I have a more immediate problem. I have fixed the front puncture, put the wheel back in and locked it in but it's not spinning because of close brake pads, arrgghh I haven't touched the brakes so it should spin freely again right?
Until it spins freely. You loosen one side and tighten the other. The net result should be it sound freely but it is tighten properly. The quick release lever, assuming there is one, should be hard to close. That means it’s secure.How do I know how much to tighten it either side?
One rule of thumb is that the lever should be just difficult enough to tighten that the lever edge or pattern slightly imprints a typical hand and not so difficult that it hurts or bruises and reopening should be possible with typical hands only and not require tools.The quick release lever, assuming there is one, should be hard to close. That means it’s secure.
Yes, but any change will affect the gear change indexing - which can be reset with the little barrel adjuster where the gear cable enters the rear mechanism, but extreme changes may require adjusting the screws - really look at a manual or video for your mechanism to be sure.You're a star, it's spinning freely. So I kept loosening one side whilst tightening the side with the lock and hey presto. Same with back wheel right?
