Tyre repair
jowwy
Can't spell, Can't Punctuate....Sue Me
Yesterday my 1 ride old gp4000s II lost in a fight with a sharp object ajd sustained a cut all the way through to the tube....resulting in a blow-out. Fitted new tube and got home ok
Question - as the tyre is basically brand new......would you glue in a tyre boot and carry on using it?
Or
Would you replace the tyre altogether?
Loch side.
It depends on the cut and how fastidious you are.
A cut implies that the cords have been cut. Since they at as a constrictor of air pressure, the tube under pressure will still push through the cut, even with a boot of sorts. A way around this is to boot it with a non-stretch boot such as a piece of coke bottle plastic. However, this makes a schlop-schlop sound with each when revolution as if you have a Chihuahua stuck in the knobblies of your MTB tyre. The plastic doesn't flex like the tyre should and quickly causes a wear spot.
I would say that if you can make such a boot and it holds air pressure, use that tyre as a backup and get a new tyre.
I would recommend a brand that doesn't throw off strings which tangle in your brakes.*
*My tongue is firmly in my cheek with that comment because I know how you love Conti's.
The 4000sII's are brilliant, right up until you hit something sharp. I lost a brand new one, after one ride, when I hit a sharp (ish) Flint. It effectively wrecked the tyre. Although I love the performance of those tyres, I've gone back to Schwalbe D+, because they don't disintegrate when you hit anything worse than pea shingle. In answer to your question, use a tyre boot in the damaged tyre, until you sort out a new tyre. The tyre is effectively goosed, so take it easy in the mean time.
J
jowwy
ok - tyre thrown to the lions..........new one ordered
conti 4 seasons for commuting
J
jowwy
just as a side note - its the first time i have punctured a 4000s in 3 years of commuting on them.......it just happened to be a brand new one fitted last weekend
h0lly1991
Slough
At least you weren't on a decent when you hit the debris had the blow out.......I've heard hot rim blow outs are dangerous as well.
gbb
Peterborough
Im close to ordering a pair of GP4000s to replace my Gators. I had a 6mm slit through one gator tapering to maybe 2mm on the inside and it allowed the innertube to squeeze out over a short time and of course get damaged.
I used a couple inches of emery tape, rough side to the tyre, as a boot...and it was very successful. Each repair lasted maybe 3 months till the fabric of the emery tape wore out. I ran it all year like that...maybe 5 or 6k miles.
J
jowwy
I was on a descent and hitting nearly 30mph...............disc brakes stop very quickly lol
