jack smith
- Durham
As above male sure you remove what debris caused thr puncture, line the logo on the tyre with the valve hole so its easy to track down
Depends on ya weight and the riding!I thought 25s could be run at lower pressures than 23s, (more comfort without increasing rolling resistance being the main reason for moving towards 25s), looking at the sidewalls in the above link they both have the same range, 100-145psi.
For some reason I thought 25s would be OK at around 80psi, am I wrong?
more weight more pressure?Depends on ya weight and the riding!
yeh i checked em, seemed fine if a little hard and close inspection they show signs of minor cracks on the surface, ive done a couple of rides inbetweendid you check the tyre properly after the first one?
got me rubinos too like a month ago daily communing and ride outs (up to 20 miles) no punctures at all and i already had to rode thru shattered glass and tarmac full of **** and they are perfectly fine, couldnt ask for more for that price, also i got them for 15 for a pair at halfordswhen you bend your bike hard (in a turn) you can actually feel the increase in grip or at least i do when hard bending.
think so, btw there are two types of rubinos normal and clincher, clincher has twice as much tpi but other than that there are no differences, ive got the "normal" version tough.
double luck for me ive just checked them @ halfords again and the black-yellow colour ive ordered is out of stock![]()
