UK Leroica Rules
  • Thread starter Deleted member 35268
  • Start date
Anyone know where I can see the rules for UK Leroica compliant bikes.
I want to do a ride in May but my 1983 bike has lots of new parts on it (still).
This post will get moved to the classic section i guess. Ooops
OK, I can put the gearing back on the downtube (I have a right hand lever already).
I have older style pedals (somewhere)
I will get some Wilkinson Wheels - tyres I will think about.
No mention of the derailleur mechs as such.
DCLane
No I don't. Will have to do it on a budget
You don't need to spend that much. It's pre-1987 with downtube shifters, although in reality they're only bothered about downtube shifters.
What size? I've a vintage Terry Lambert 58cm shorter frame available (£200 with new tubs - when I've got round to sticking them on) or a Peugeot Premiere 54cm ready soon (£100).
I got a bike already - It just has new parts here and there. Sorry. N +1
biggs682
Northamptonshire
Thats good to hear , never like to miss a chance :smile:
GuyBoden
Warrington
https://eroicabritannia.co.uk/rules
"6. Brake cables must pass outside the handlebars"
What exactly does this rule mean?
Does it mean you can't wrap your cables onto your handle bars or does it mean no internal cable routing through the handlebars.
Cables have been wrapped onto the handle bars since mid 1980's at least.
Here's the 1986 TdF.
biggs682
Northamptonshire
i take it as they cant be wrapped ie non aero levers
hoopdriver
East Sussex
Odd that they are so fixated on downtube shifters. I vividly recall a Schwinn "10-speed" I had c1969-70 that had shifters by the stem, and a touring bike I had in the late 70s - a Gemini World Randonneur - with bar-end shifters - both apparently would be deemed "unauthentic" for the purposes of a pre-1987 vintage ride.
Essex
Odd that they are so fixated on downtime shifters. I vividly recall a Schwinn "10-speed" I had c1969-70 that had shifters by the stem, and a touring bike I had in the late 70s - a Gemini World Randonneur - with bar-end shifters - both apparently would be deemed "unauthentic" for the purposes of a pre-1987 vintage ride.
Eroica Britannia has a slightly different set of rules than the Italian version, which explicitly allows pre-1980 non indexed bar-end gear shifters and rod/hand manual operated front derailleurs.
In reality, no-one actually polices the Britannia other than the goodwill of the riders, and everyone makes an effort. To quote myself from a recent blog post, Eroica Bike Guidelines and Why They're Important:
"A straw poll, conducted by yours truly, wandering around the fields and lanes of 3 separate Eroica events reveals that thankfully most folks are smart enough to do their research and tell the difference between an eligible bike and a non-eligible bike.
Don’t be that guy who does turn up on a bike like the one above. You’ll spoil the fancy dress party for everyone else, you’ll put the marshals, volunteers and your fellow riders in an awkward position and you’ll look a knob.
There are plenty of things you can do with a bike like the above (even excluding stripping the groupset and re-selling it to an Eroica-nut) It would make a smashing commuter or winter bike, I dare say it’s light, stiff, responds well to out-of-the-saddle efforts and all sorts of other Bikes Etc adjectives.
It’s just not very heroic."
The brake cable rule is exactly as described above - that by asking that cables pass up and over the handlebars, though they can be internally routed thereafter, it excludes aero brakes and anything that even looks like a brifter.
Similarly with rear derailleurs - anything that looks suitably vintage, irrespective of age, does nicely. New Campagnolo Veloce is very popular, and is used on the Bianchi l'Eroica so must be ok. Basically, if it's modern you can style it out with a silver mech, but not a thumping great black plastic long-cage mech.
Gear ratios are free-range and a matter between you and your knees. ^_^
Richard dickson
Regular
Cornwall
Erocia.
Steel frame. As old bits as possable. No index gears. Anything built or made pre 1987.
Or new bits made in same style as old pattern parts.
Light blue bikes of Cambridge make compliant brand new bikes!
