Thinking of upgrading bit by bit, so my question is will an Ultegra 6800 rear derailleur work with a Sora 9 speed lever if i adjust the limit screws to the right place...Cheers
Probably not. I'd guess you'd need the levers to match the derailleurs & cassette...at least in terms of gears...
Might get away with a different chainset and blending that in though - I have Claris levers & derailleurs mixed with a Sora chainset and that seems to work ok...
No it wont work. 11-speed uses a different pull ratio (or leverage if you like) than previous generation derailleurs. Same with the 6800 front derailleurs. Think DynaSys - same thing.
