USB powered Front light!
Edinburgh
I am tempted to get one. I have mini usb chargers already for phone and cameras, so already have the home and work fronts covered, no need to remember the cable.
Looks like a good burn time as well.
benb
Evidence based cyclist
Epsom
Hmm. Might be OK as a secondary/backup, but I don't imagine it will be very bright.
Z
Zippy
I run the battery recycling for my colleagues at work and they usually come to me used but not quite burned out (the batteries that is; not my colleagues), so can usually get two or three hours out of AA and AAA batteries before I finally take them for recycling - can get me through the year at no extra cost!
I quite like the idea of being able to plug in my front light at work and never having to use batteries, but can't imagine it is bright enough for anything other than a secondary blinker.
jimboalee
Solihull
The initial charging current of a NiMh cell is 1C. That is... a 2000 mA cell ( 2.0A ) will recieve a starting jolt of 2A charging current.
I have a Tesco 'Smart charger' with a thermocouple ( probably a Platinum Resistance Thermometer PRT ) that kicks off at 2.0A and reduces to 0.2A when the cell temperature has reached optimum.
How much current can a miniUSB take? How much current does the USB on the side of a desktop PC pump out? Not enough I expect.
If you really want to trickle charge a NiMh cell, expect an overnight duration.
thomas
the tank engine
Woking/Norwich
Looks like a good idea. If you get to work, it's easier to carry (or at least find) a USB cable to charge your light up...rather than hvaing to cart a standard battery charger (mine's quite big...much bigger than usb).
Dont think it would fit on my handlebars.
Another problem is I don't sit next to a computer all day with USB ports.
You get these wall plug USB chargers now - VEHO do one, so handy for the bike cameras too!
For the non IT cycling geek.
You can charge almost anything from USB.
At 500mA. Not all usb ports even supply this (100mA).
Which is a bit pansy.
Better off investing in a wall charger, and some AA + AAA NiMH.
