I have a good few millimetres of play in my Campag veloce 10sp rear hub that I'd like to try and adjust out. No cup-and-cone nor lock nuts, just cartridge bearings and no obvious means of adjustment.
I've read on bikeforums.net to just tighten up the axle bolts a bit more and then tap both ends with a hammer and check for play again. Would you agree?
I'm a tad nervy about tightening it up too much. The hub spins freely with no noise or grinding so I'm assuming the bearings are still good (around 10k km).
