I had one fir my 6 and will probably still use that fir rides though I dare say x cases are available.Neat, I will have to look that up, I know you are iPhone fan, so, I assume that is iPhoneX compatible?
I find its not the dropping at 20mph that kills it it is the line of traffic behind you that does the damageHave you dropped it at 20mph plus onto the road.
The best and indeed only way I’ve destroyed a garmin
Other than one having trouble finding a gps signal I have had 40000 + incident free Kms with garmin gps’s
The only two issues, not problems, I've had with my Elemnt, is that on night rides, it could do with an option to illuminate the screen momentarily when approaching a turn rather than have the light on permanently and run the battery down. All that happens at the moment is that the LED's flash red when I miss a turn.
Also, when I stop to check my route, the Autopause notification covers most of the map.
With TCX files using the 30m notification, the screen lights up for a short duration. But in general, when I am doing longer Audax rides that start and finish in the dark, I use my head torch. I don't want to lose the power on the device by having the backlight on too long.
I have the Bolt and it gives you a pre warning beep before you get to the junction and then a beep at the junction along with the LED's showing you the way. Maybe its different with yours.
My old Garmin was good for double that, the Wahoo i now use is supposed to be even longer battery life, Sounds like you need an upgrade.Use your phone instead. Never had a problem, much much clearer screen and with my charging case I get about 7 hours battery life.
Re q1, have you starred them on Strava?I have an Elemnt which I'm very pleased with. Recently I've run up against two questions, not issues but things I'd like to resolve.
1. After syncing with RWGPS I have three routes which can be seen in the route list which are "STARRED" and if I sort by this selection will show up as well. These routes do not exist on my RWGPS account. I've tried logging in and out, cleaning out all the old routes on RWGPS which I don't need and re synced several times. It's a minor irriation but I'd like to get rid of them
2. When I sync with RWGPS the Elemnt shows it has synced and stored 84 routes - I only have 81 in my RWGPS account, see above. I had been under the impression that the Wahoo device only stored routes one chose to send to it by selecting them in the Wahoo app. I prefer only to have the route I'm riding on my device at anyone time. Ideally I want to select a single route in the app, send it to the Wahoo and then ride it!
Given it's the same number, that is my guess! Check your starred routes on strava, not just your own routes?Thanks. I had already checked Strava and deleted the three routes I had there. I'm going to turn off the link to Strava, sync and see what happens.
Try pressing the bottom right button..
