I came downstairs earlier to find a 4" diameter pool of water underneath the bottom bracket of the new bike
Instantly my mind started racing to all manner of questions and dire scenarios... the bike hadn't been out in the wet but was (carefully) washed over a week ago; raising images of my mind of fap knows how much water sloshing around inside my frame, merrily corroding everything it came into contact with.
Why take so long to finally make its way out of the frame though? I removed the (nearly full) water bottle and inspected it for damage, finding nothing.
I unscrewed the retaining bolt for the cable guide on the underside of the frame expecting a torrent of water, but found nothing other than some pristine grease. I pulled out the seatpost and inspected inside the frame; finding nothing really other than a bit of light surface corrosion below the lower edge of the seatpost.
I took the bike outside and left it in the sun with the seatpost assy removed in an effort to dry it out. Bizarrely water began accumulating beneath the BB again..
I again removed the (nearly full) water bottle just to be sure; to find a small trail of water leading down the outside of the down-tube to the bottom bracket.. turns out that the lid wasn't properly fitted to my bottle (probably as a result of it falling out of my bag - again- yesterday since I can only carry one bottle on the bike currently) - this was evidently enough to allow a small amount of water to seep out at the join.
Feelings of muppetry greatly eclipsed by the reassurance that I've not just potentially ruined my new frame by filling it with water for a week, although it's raised the inevitable questions about interal rust proofing; so something else to worry about..
