DaveReading
Don't suffer fools gladly (must try harder!)
- Reading, obvs
We have a fairly elderly water softener, still working well and making a world of difference to our previous limescale problems.
Unfortunately, a few years ago and for reasons I can't remember, I filled it with water while it was resting on a couple of bricks and the weight of the water caused a hairline crack in the bottom of the outer shell. It now suffers from a minuscule leak - there's not normally any water evident, just dried salt on the outside as the small amount of leaking brine evaporates.
It now sits in a seed tray to stop the floor tiles being contaminated, and every few months I wipe away any salt deposits, but I'd like a more elegant solution (npi) to the hairline crack leak.
I'm thinking in terms of either some kind of membrane or waterproof coating that I can apply to the bottom of the shell, inside, to make it watertight once more. It would need to be food safe (alhough we don't actually drink softened water) and not be affected by the brine.
Any suggestions? Thanks in advance.
