Weld failure - Not cycle related
PK99
SW19
Just posting here on the off chance that there may be someone who can advise...
Picture below shows a failed gate hinge. Post is cast iron. Hinge pin unknown.
Hinge failure deposited gate on MrsPK's foot causing serious injury.
Insurer of gate owner is playing hardball.
Does the weld look dodgy? To my amateur eye yes but ias there anyone here with the professional knowledge to advise?
Pic taken 2/3 hours after weld failure.
Edit. Gate and post constructed in 2014
Drago
The Urban Fringe
Looks to me more like the weld has pulled a chunk of metal off the post?
What's the insurers problem? They cover the gate, the gate dropped on someone's foot, they pay up...surely?
P
PK99
SW19
As I say.they are playing hardball and denying liability.
classic33
Leg End Member
Yes looks identical.
Either never properly done, or else it's been going for a while. There's rust behind the weld.(Left-hand side).
P
PK99
SW19
Who actually owns the gate?
It's normally a boundary marker, which might explain them denying liabilty.
Next door neighbour! It is front driveway gate ie very big and very heavy.
Among other things they are claiming hight quality construction.
P
PK99
SW19
Guess that the post and gate frame are the same type of iron. Cast iron is seldom used these days.
Cast iron replica of traditional gateposts used in conservation area.
Original posts are 3 sided with internal wooden post. Hinges are bolted through both and do not rely on a weld. Replica is 4 sided hence welded hinge support.
