For A2C of 410mm, we are talking about 60mm travel forks to maintain bike geometry, and 80mm travel will probably be the limit to not noticeably affecting handling.
If you look at the database
here, you will see that 80mm forks typically have A2C of ~455mm or so, taking 25% sag of 80mm off and we are talking about 435mm, which is 25mm more than the original. This will give rise, all else being equal, an increase in trail of ~8mm by slackening head tube angle by over 1 degree, making the steering more sluggish.
I would say you definitely don't want 120mm forks, and not even 100mm.
It seems the limits are 1-1/8" aheadset (which is great since it is most common), with brake bosses, up to 80mm travel, minimum steerer length of 195mm - assuming you don't want or can't have shorter than existing - but would you like it longer to reduce weight on wrists? If so how high has the spacer stack been below the stem, if any?
And how much do you want to spend?
