What are these tidbits?
Kookas
Exeter
These came with my Felt Z95, what are they?
cosmicbike
Perhaps This One.....
Egham
Any chance of a link that we don't need a password for?
Edit:- Thanks...
Shut Up Legs
Down Under Member
Could the small pin on the right be a spare chain link pin? I can't tell its size from the photo, because there's no common object with which to compare it.
Kookas
Kookas
Exeter
From left to right...
1. shims to adjust the reach on the levers
2. don't know
3. sleeve nut (holds the brake caliper on)
4. rubber bung to go over the hex bolt in the top cap
5. bar tape (don't know why this is useful)
6 looks like a shimano chain link pin
Thanks. Fitted no. 4. for completeness, but it seems odd to provide a spare nut for the caliper and nothing else.
Cuchilo
Prize winning member X2
London
The thing that looks like bar tape looks like it has grit on it . The 3 on it could be 3 M and that's a grade of wet and dry sand paper I think . On the other hand if it is bar tape then its for putting at the rear of the hoods before you wrap the bars incase you miss a bit .
2 looks like its part of 1 .
It's bar wrap, with a 3M adhesive backing strip - it's not grip tape.
Kookas
Kookas
Exeter
Well, sounds like I won't be needing any of it any time soon. I have to say, though, this bike looks and feels so much higher quality than my old bike. No wonder people spend thousands on theirs.
Banjo
Fuelled with Jelly Babies
South Wales
middle one looks like the threaded tube you put through the hole in your fork crown to screw the brake caliper on Pass on the rest.
