Kr4t0z said:Thanks guys! Really helped.
Another question: What if I wanted to change the way cables are managed like stick them to top tube etc. And what do I need to do that?
Thanks,
Kim
Thanks,
Kim
02GF74 said:you may not be able to do that.
you need to understand how a cable works. it has inner wire and an outer flexible but largely incompressible tube and the outer needs to be fixed at each end to something which does not move for the system to work.
basically you will find cable stops for the brakes and gears attched to your bike, either soldered onr or welded on, and the outer must butt up against them - this will limit on the way you can run the cables.
